跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
iPhone 3GS Coil problem
Hello,
i have problem with my iphone 3Gs.
I tried to replace the coil but when i wanted to remove the old coil the old solder pad (connector on the mainboard) was also removed.
So the problem is that i dont have only one point to solder the coil.
Is there any other solution to let the backlight work?
I found that but maybe there any other solutions:
http://s1.directupload.net/images/111222...
Please help me to find a solution.
Thanks
Update
Thanks for your information. Here a picture of it:
http://imageshack.us/f/560/cimg0661z.jpg...
Now it is easier for you to help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
Have you got a photo of your damaged part on the board?
完成的
This is why I dread replacing the 6R8 coil so much, too easy to damage the logicbord(expensive!) I refuse to do this EXCEPT on iPhones given to me so if it fails, I can keep it for parts
完成的
Fuad, if you want to send it to me to take a look at, I can. No charge unless it is fixed.
完成的
添加一条评论
1个答案
最有帮助的答案
If there is even a hint of trace left, you can dig up the fiberboard and get a better connection to it. You could do that jumper trick, but it is a bit difficult to do if you don't have experience with this type of thing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fuad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,438
