跳转到主内容
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 个问题 查看全部
Have vertical gray area from top to bottom, rest of screen works fine
. This is what it looks like. Rest of screen works and if you can "guess" under the gray, can click/select the item. Have done all the usual resets, etc. also changed the display cable. Probably something in display... can that be fixed or have to be replaced?
Update (06/17/2022)
So next time I fired the iMac up, it was not an all gray area, but partial top and bottom with a thin blue vertical line. So I used a screen grab of the area, including the missing data part) and it showed up fine. That should mean it is the display is defective. Sadly will order a replacement. Hope this is the right solution. Any comments folks?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@macman67 your screen lost complete contact with the ribbon cable that is coming from the driver board to the display. Since those are attached via a special bonding process, it is not a good DIY’er repair. Yes, replacing the display will be the prudent thing to do
这个答案有帮助吗?
得分 2
1条评论:
Experienced repair, so will give it a try. Also order a replacement screen. Thanks.
完成的
添加一条评论
Thanks, heat "rebonded" the cable on that section and all is well again. Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carl Schultz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 83
