跳转到主内容
Repair guides and support for gas and electric hot water tanks, boilers and household heat exchangers.
32 个问题 查看全部
Why won't vinegar circulate while flusing tankless water heater?
Trying to flush Rheems tankless gas water heater. Turned off the gas first, then unplugged it per plumber's advice. Inlet and outlet valves all shut off. Hose connection valves on. Using a 1/6 horsepower pump. No flow of vinegar through the heater. Reversed hoses and got just a trickle. Cleaned filter, still nothing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@bpcammack take a look at these instructions and see if they are consistent with what you did or if not, if it works for you.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for supplying me with this. The only thing I did differently was to shut off the valve to the outlet. Let me open it and see what happens. Thanks!
完成的
添加一条评论
添加你的答案
Bruce Cammack 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 32
总计 932
