跳转到主内容
加入维修社区 - 创建账户
Computer has no admin account
So I got an SSD with El Capitan and lots of apps pre-loaded. Somehow, the only account on the computer is not the admin, so there is no admin account. How does this happen, and is there a way to forcefully create an admin?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
I have seen this happen a few times before and the way I have always managed to resolve it is by running a command in single user mode to modify the drive so that it thinks account creation was never done. So you can create a new admin account. Grant admin to the account you want and then ditch the account you just made.
There is a fairly comprehensive step by step on this here:
https://logi.wiki/index.php/Single_user_...
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
It can happen when one creates a new account to delete the existing one and forgets to make it an administrative account. Then logs in the new user, deletes the administrative user by supplying the admin password, et voilà, makes the Mac almost unusable.
All you can do is save the Apps you're interested to on a pendrive and reinstall from scratch. Licences of the paid Apps have gone one way or the other with the old user that was cancelled. You can use either the original disks, create a Usb pendrive, or reinstall via the internet if you have a fast enough connection.
https://support.apple.com/en-us/HT204904
这个答案有帮助吗?
得分 3
添加一条评论
Hi @guardian10
That is strange isn’t it,iv never seen that before
I don’t mean to be putting you from Website to website but for this one I would actually get on a live chat with apple support and see what they think
The reason why I think you should do this is because it might be a bug that can be patched with a small update so other people don’t encounter this issue
这个答案有帮助吗?
得分 2
2条评论:
It's a 2011, so wouldn't Apple deny it for it's age?
完成的
@guardian10
I don’t think they would as not so long ago i phoned up and started asking about a 2006 iMac and they helped
So I would imagine that they would do a 2011:-)
完成的
添加一条评论
Try going under System Preferences - Users and unlocking it and adding an account and see if you can set it up as an Administrator account.
这个答案有帮助吗?
得分 1
2条评论:
The problem is that I can't unlock it because the admin account doesn't exist.
完成的
@guardian10 I'd try using Migration assistant using another Mac in Target Mode.
完成的
添加一条评论
添加你的答案
guardian10 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 44
总计 2,756
