How can I fix too loose ZIF cable?
I'm trying to fix an old nintendo ds. I disassembled it and I tried to connect all the ribbon cables in their location.
I noticed that the ZIF connector of the top screen is "too loose" and this is a problem because even a little movement makes the ribbon cable get out of the connector.
The same thing, for example, doesn't happen for the bottom screen. It seems it has a stronger grip.
How can I fix this?
I was wondering to apply some tape on it but I don't know if it is a good solution.
Any suggestion is appreciated.
1条评论
@twiggy7 I'd add a few strips of capton tape to the non contact part of the ribbon cable etc. Just enough to make sure the clasp is still locking properly without being to tight. Too much and you may actually break the connector.
由 oldturkey03 完成的
