跳转到主内容
Repair guides and support for the Galaxy Tab S6, released in August 2019. Model number: SM-T860NZAAXAR
34 个问题 查看全部
Galaxy tab s6 lite heating after liquid damage
Hi, I have a galaxy tab s6 lite. My sibling spilled water to tablet and it started to heat around the top of the tablet. Screen works fine for 10-15 seconds and stripes appearing at screen. I turned off tablet for a while and problem is still there. Can anyone help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Alper this "started to heat around the top of the tablet." is a pretty good indication that you have something shortening out or already failed. You do have to take care of the water damage first.
For now you want to stop continuing to try to charge, sync or otherwise use your tablet. This potentially can make a bad situation worse since it may further damage your phone.
The next thing to do is to clean it. Disassemble your tablet using something like this video You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you remove those, clean all the boards, connectors etc., +96% isopropyl alcohol. Isopropyl alcohol in the higher concentration will evaporate quickly and there will be no reason to wait for any drying. Follow this guide , and even so it was written for an Apple iPhone 3G, all the points are still pertinent to your tablet. If you have to use water to remove any gross contamination, use sterile water and not drinking water. The importance here is the cleaning. While you clean your board, check for any obvious damage, like burned or missing components etc. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, change your battery and reassemble your tablet and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
这个答案有帮助吗?
得分 1
1条评论:
Thanks for help.
完成的
添加一条评论
添加你的答案
Alper 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 41
总计 768
