跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
Why does my Xbox One S turn off immediately?
Note: I already replaced the power supply with a fully working one from iFixit (New) but it still gave the same result.
After accidently dropping my Xbox, it beeps and turns on for about 5 to 10 seconds then shuts off. I have a feeling that it's an issue with the hard drive as it makes a charm after the Xbox One S turns off, but I just want to make sure as I don't just want to waste money.
Update (06/02/2022)
Front Mother Board - https://imgur.com/a/rswPhrX
Now after viewing the backside, I was totally surprised to see how dirty it was. Water Damage? Now that I think of it, I think it's the motherboard which sucks lol.
Link: https://imgur.com/a/ucfK4ZW
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@xdstarr definitely some water damage. First thing you need to do is to clean that board. Remove the heatsink etc from it and get some high grade (+90%) isopropyl alcohol. Poor it in containing large enough for your motherboard and then soak the board. Use a couple of soft brushes and "gently" clean the board. You do not want to scrub it since that potentially could knock components of the board. You can use something like this guide Even so it was written for an iPhone logic board, all the points are still pertinent to your board as well. While you are cleaning it, you need to look for any burned, charred or missing components. Those can be replaced and traces can be fixed if needed. Post some good, clear, large pictures with your QUESTION after it's cleaned so that we can see what you see. Pay particular attention around area D9 on your board since that is where the power IC's etc. are located. 在已经存在的问题里加入图片
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 1
添加一条评论
i see a lot of red flags man can u show me the bord Cuz it could be its not getting power or a component on the bord could have broken or even a loose port so i need more info plz
这个答案有帮助吗?
得分 0
1条评论:
sarry buddy i think u should take it to someone for a second pair of eyes u know what i mean i am limited by pixels lol but Ya that looks like it needs work
完成的
添加一条评论
添加你的答案
Bryan Jimenez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 434
