跳转到主内容
加入维修社区 - 创建账户
HP 14 系列笔记本电脑的维修信息。
Can this be fixed .
Can this be repaired in anyway
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Hi,
What is the model number of the laptop and shown on the information label on the bottom of the laptop?
由完成的 分享
@jayeff 192T6UA#ABA or 5CD0475RX9 not sure if this is what you meant
由完成的 分享
@Phillip Williams
I thought it might be something like HP 14s-fq0013dx or similar as knowing the exact model number will help to find the correct parts by locating the maintenance and service guide to know what the part numbers are for either the lower case assembly or display cover if the hinge screw mounts are broken or new hinges.
由完成的 分享
@jayeff oh right its HP 14 fq0013dx
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Hi,
Here's the maintenance and service guide for the laptop, from this support webpage
On p.19 items # 6 and #8 you will find the part numbers for the hinges and the display back panel and on p.17 Item #15 the bottom cover.
Depending on what part is the problem, (my eyes are bad and I can't see it that well in your image) if you search online using the appropriate to your particular model variant e.g. colour of case/display cover if applicable to faulty part, part number only in the search term of your browser, you'll get results for suppliers.
The guide also describes how to completely and safely remove all the components to make it easier to see what the problem is and to fix it.
这个答案有帮助吗?
得分 2
添加一条评论
From the photo it looks like the rivets that are used to attach the screen to the hinge have broken. Can it be fixed, definitely. However, you're going to need a new back panel, and you'll need to transplant the old screen from the old back panel to the new one.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Phillip Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 331
