跳转到主内容
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 触控转盘
Both iFlash board and HDD not working
Yesterday I installed a iFlash ATA1 board in my iPod but keeps showing a folder icon and a dead iPod.
(I've tried every drive format such as FAT32, exFAT and Mac OS Extended journaled and even tried using a SD card from a different brand that would work in the iFlash boards)
I put the HDD back in the iPod it booted normally so I knew that my cable wasn't broken.
When I tried to put the iFlash board back in the iPod it still didn't work and the HDD doesn't work anymore.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@scharre possible that the iFlash shortened out the board or the connector. Verify all connections etc. Place the iPod in Diagnostic Mode as described on here ( as well as on here and multiple other places) and see what it tells you. Get a USB to Zip connector and see if your computer can still detect the HDD when you connect it via USB port.
这个答案有帮助吗?
得分 0
2条评论:
I tried resetting the iPod by holding down the menu and play/pause button and it booted (so that's great).
Now says that the hold switch is still turned on even when i turn the hold switch on and off
完成的
I also looked on the back of my iFlas board and there are no connection points to short on the board (just to let you know)
完成的
添加一条评论
添加你的答案
Scharre 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 444
