跳转到主内容
加入维修社区 - 创建账户
Logitech M170 是罗技(Logitech)推出的一款无线鼠标,于 2016 年发布。
Wheel randomly scrolls in other direction
Hi. The problem is when i want to scroll down or up it goes to the other direction, sometimes more or less.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
添加一条评论
2个答案
最有帮助的答案
The trick is the WD-40 spray. It's a spray that can be bought at any hardware store worldwide. It's world famous. Just spray a little bit in the side of the mouse where the scroller uses a small wheel which is attached to the circuit.
I found many answers saying to use WD-40… at first I was very apprehensive, but it worked like magic.
Spray it, leave it upside down for 10 minutes and then test the scroll with an open top before closing it permanently. Amazing liquid.
这个答案有帮助吗?
得分 2
2条评论:
could you guide us on where exactly we should spray the WD40 im a little confused
由完成的
You don't spray directly onto the area. You spray into the cup (cover of the bottle), as shown in the video and use a stick to apply on the motor or the sensor.
Just see the video. You will understand
https://www.youtube.com/watch?v=cVKXUiXl...
由完成的
添加一条评论
From what I understand, we need to open up the mouse and clean the scroll. But the biggest issue is opening it up. Its super hard. There are 3 clips in the battery compartment. I have bleeding fingers trying to open it. No success. Maybe I need to buy an iFixit kit.
See these videos :
https://www.youtube.com/watch?v=Kem0TE3U...
这个答案有帮助吗?
得分 0
1条评论:
It wasn't that hard to open the top cover. Just loosened the three clips using the below instructions:
拆开 Logitech M170 外壳
And then cleaned the scroll. It's working perfect now.
由完成的
添加一条评论
添加你的答案
Rafał Barański 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 99
总计 2,809
