跳转到主内容
加入维修社区 - 创建账户
Ryobi P214 是一款无绳冲击钻,使用 18V 锂离子电池供电,配备 1/2 英寸夹头,最大扭矩可达 600 英寸-磅,转速为 0-400/0-1600 RPM。本页面提供了 P214 的详细信息和维修指南。该工具具有用于砖石钻孔的冲击功能、24 级离合器设置,并兼容 One+ 系统,可实现电池互换。
Can't remove chuck from drill
I have the ryobi p214 cordless drill and no matter what I cant remove the chuck. I took the screw out from inside the jaws and I put an allen wrench in and held it with the jaws. I managed to turn the chuck counter clockwise but it just barely spins without loosening at all. How can I get the chuck off?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
@archiep once you got the allen wrench locked, you placed your drill in REVERSE (lowest torques setting)and you do have a full battery? Now pull the trigger. Careful, It'll kick a bit and you got to hang on to it and watch your wrist.
完成的
I did this, but the drill started smoking and it also kept auto braking unfortunately.
完成的
I have the same problem? I cant tighten the chuck enough to stop the drill bit just spinning in the chuck , so , I want to fit a new one but cant remove the old one? Cant see any screw / bolt up inside the chuck at all? Hopeless system?
完成的
Had the same problem so dismantled the drill down to the point where I had just the shaft with 2 flats on the end, clamped it in the vice , 10mm hex key in the chuck and heated the hell out of the old chuck, it let go with a bang and the thread is not a 1/2" 20 thread as mentioned, still to indentify, be careful during disassembly as a lot of small gears and parts, photograph each stage.
完成的
Also good to note that the screw is a reverse thread
完成的
添加一条评论
1个答案
最有帮助的答案
A few things that may help; first instructions on how to deal with the situation. here next a reminder that this has a 3 year warranty in case that still applies and your owner's manual here in case you need it, which gives instructions on pursuing your warranty or service. Last; schematics and parts are available here
这个答案有帮助吗?
得分 1
2条评论:
Thank you for the useful content, however, the article link is doing something different than what I'm trying to do. I don't have a bit stuck in the chuck, I'm trying to remove the chuck from the body of the drill. I used the schematic you shared to illustrate my situation.
完成的
OK, well, in the very unlikely event that @oldturkey03 's advice didn't do it for you, (he's a pretty darn sharp tack) I did find an answer to that too...somewhere but should have read your question more carefully.
完成的
添加一条评论
添加你的答案
Archiep 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 54
总计 2,704
