跳转到主内容
加入维修社区 - 创建账户
于 2019 年 6 月 28 日发布的 VR 头戴式显示器。
Dust on both display panels
When I moved, I somehow managed to get dust inside the headset and onto the display panels. I know it's not on the lens, because moving the IPD shifts the lenses but not the dust specs. Would replacing two (left and right) eye tube assemblies fix this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I have a similar issue including scratches and possibly pixels but i cant distinguish if its pixels or dust on the left eye and would also like to know if the tube could remedy this
由完成的
I used compressed air when I shouldn't have and ran into the same issue, I figured if you can make a strong enough wind current in-between the lens and the display you can pull out any dust, but any solution involving taking the screen off the back of the display cone wont be easy, Ive tried. The only other solution would to be to replace the display cones and maybe replace the rubber seal around the lenses to keep more dust from getting in.
由完成的
添加一条评论
1个答案
最有帮助的答案
Your problem may not be dust, but my in fact be dead pixels. Regardless, both of these are common problems on the Valve Index
Dust is much less likely being that the eye's are sealed with adhesive, but it is still a possibility. Dead pixels are significantly more common on the index due to their choice in components.
To answer your question: Yes replacing both the left and the right eye tube will fix this issue.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
BBlaze 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 1,880
