跳转到主内容
加入维修社区 - 创建账户
HP EliteBook 850 G3 是 HP EliteBook 800 系列中的一款商务笔记本电脑。它属于 HP EliteBook 的第五代产品。
Power LED blinks white and orange
This is the second machine I've seen in a week with the same problem, or at least very similar.
The one on my bench presently is an Elitebook 850 G8, the one I replaced a system board on was an Elitebook 845 G7. As soon as any type of power is connected, either battery or AC adapter, the charger LED will turn on white, but blink amber simultaneously. I believe it blinks 10 times. I have been unable to find any documentation for this specific error. This persists even if I remove connections from the system board to any other hardware aside from whichever power I am connecting. Even trying to power on with no RAM gives this error, will not beep/blink to indicate the system does not detect RAM. I do not even need to indicate power on for this to occur. As soon as there is enough contact with whichever connector to transmit the necessary power, it starts.
I have even tried running a BIOS recovery to no avail. This 850 G8 on my bench seems as though it will try to power, keyboard backlight will come up, Caps lock LED will light steady, no blink codes. It's under warranty, so ultimately it's probably going to get a new system board, but I want to know what this error is.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
3条评论
Hello ,i hope you're whoever is reading this .
I have the same issue whenever the laptop is connected on battery or A/C power the charging light blinks white and orange and the Caps lock lights up and the pc won't turn on i have tried disconnected evry single piece of hardware one by one but nothing the problem persist , if anyone could help please 🥺
由完成的
If Caps Lock lights I think you got further than me. Caps Lock lights up solidly? Or it blinks?
由完成的
I have the same problem and mine is solid
由完成的
添加一条评论
1个答案
已选择的解决方案
In case anyone else stumbles across this. This sequence of blinks signifies the device is shutting down/ powering off. I ended up trying a different charger, as well as attempting to charge through thunderbolt, which gave slightly different behavior. Seemed as though it was charging (would give a solid orange light for a few seconds) and then give this set of blinks again.
I was unable to find the exact fault in this case, I have much less experience with PC board troubleshooting, but since the unit was under warranty I replaced the system board, which resolved the issue.
这个答案有帮助吗?
得分 2
3条评论:
Any updates on how it got fixed?
由完成的
@talhaimtiaz This unit was under warranty and I replaced the system board which resolved the problem. Even under warranty, system board replacement is usually a last resort. I typically try to be sure that's the issue before I go that route, and on this repair I ran out of options.
If it had not been under warranty, I likely would have done some deeper digging. Especially since I determined it was a power related issue.
由完成的
bro you just need bios flashing and it works perfect
由完成的
添加一条评论
添加你的答案
Alisha C 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 72
过去 30 天: 345
总计 41,647
