How to change rear battery cover?
I want to change the rear battery panel because it's got some using marks and looks really bad
ybo.shooter check this video you need a heat gun as your main tool. Temperature on the back cover should be around 70deg C to loosen the adhesive. Not complicated just a bit tedious.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 481
