跳转到主内容
加入维修社区 - 创建账户
Motorola One Action 于 2019 年 10 月 31 日发布,是谷歌“Android One”计划的参与机型(该计划保证提供“纯净”或接近原生的 Android 操作系统,并优先支持谷歌服务,而非 OEM 品牌的定制方案),型号为 XT2013-1、XT2013-2 和 XT2013-4(代号“troika”)。
No one can hear me...
No one is able to hear me when I call and they answer the phone. I have already restarted my phone, but no success.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
  • Is the phone in a protective case at all?
If so remove it from the case and check if you can be heard OK when using the phone on a call. The case may be blocking the microphone's voice inlet hole found on the bottom edge of the phone.
  • Try using headphones with a microphone attachment plugged into the headphone socket of the phone when making a call and check if you can be heard OK. Alternatively try using the phone in loudspeaker mode (aka hands free mode) and check.
If you still can't be heard then there is a problem with the voice transmission circuitry in the phone. The phone would have to be opened and the problem further diagnosed as to what is causing it.
If you can be heard OK then there is a problem with the phone's internal microphone or perhaps the single voice inlet hole on the bottom edge of the phone may be blocked with dust or lint etc. Do not use a pin or probe to try and clear the hole, as you may damage the microphone which is behind the hole. Try clearing the hole by using a vacuum cleaner to get any possible debris out of the hole. If still no good the phone will have to be opened and the microphone checked etc.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aaron Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 19
总计 479
