How to solder the antenna wire back on the controller motherboard?
@nytryder26 okay the antenna cable removal is around 09:00 mins. It is held in place by a small SMD antenna connector. You need to tell us if it is the connector on the board or the one on your cable that has failed. The connector on the board can be changed by resoldering a new one. It' s small so you will need somebody with some micro soldering skills.
If it is the cable there might be a way of splicing a new cable to the old one, or complete replacing it if we can see the other end. You can get replacement at multiple places. Check places like this for more info. Ipex has a variety of the connectors and I believe Digikey.com or Mouser.com has them as well.
这个答案有帮助吗?
The plug and the cord ripped off and I tried soldering and it melted the plug.
@nytryder26 none of that us ever easy just based on the size of it. The soldering on the board would be relatively easy whereas the wire, I‘d splice it or replace it if you can get to the other end.
@oldturkey03 It's super small, I can't solder it. Thanks tho
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 773
6条评论
@nytryder post some pictures of what this all looks like, with your QUESTION. 在已经存在的问题里加入图片 Let's see if we can help you with that.
由 oldturkey03 完成的
@oldturkey03 Can I send a video of someone taking it apart? https://www.bing.com/videos/search?q=how...
由 NR26 完成的
@nytryder26 you can post a short video with your QUESTION. It works the same way as posting pictures. Now if you have a longer video, you could post it on places like Youtube etc or place it on Dropbox etc. and we can download it to see what you need help with.
由 oldturkey03 完成的
@oldturkey03 My camera does not work so I can't, can you look at this youtube video pls?
由 NR26 完成的
Sure I can. Tell me what I am looking for. Some sort of time stamp....
由 oldturkey03 完成的
显示更多的1条评论
