跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
705 个问题 查看全部
Connector that keeps the Switch fan connected broke off
Hello,
I've caused a friend's switch some damage that the fan is not operating now. Everything else works fine thankfully, but it seems like the gray clamp that keeps the connection together snapped off and it looks like the pin on top broke off with it. Here is the condition it is in.
Compared to the image shown here in iFixIt:
This seems like it requires some solder work on the motherboard with a replacement ribbon clamp. Can anyone confirm this is the case or is are there any suggestions we can try?
So far, putting pressure in the area does not help nor did any electrical tape with pressure did either.
Thanks
Update (05/10/2022)
Update to @flannelist. Looks like the connectors look okay? I haven't had any luck trying to put pressure getting the fan to turn on unfortunately. I did order extra pieces of this on this site. Seems like soldering will be needed for this.
Thanks all for looking at this issue!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Connector looks okay to me too. Might some other issue down the road, but definitely replacing the connector is a solid plan to start.
完成的
添加一条评论
2个答案
已选择的解决方案
The little clip is just to keep the cable squished into the connector pins, and to keep the cable from coming loose, if the pin damage is just on the top part of the pin, I don't know that that's a huge deal and would probably just be cosmetic . Seems logical that this is related if the clip is broken off and the fan isn't spinning. But all the contacts for the fan cable are on the bottom side of the fan cable and since the cable is plugged in in your picture, it's hard to tell if there is any damage to the pins in the connector where they make contact with the cable. I would unplug that cable and inspect the connector for any other damage.
If no, it may just be that the cable sitting flat in the connector is not enough to make a strong electrical contact. See if you can use a plastic spudger or something flat and not conductive to press the cable into the bottom of the connector and see if you get fan spin that way. Otherwise, I would check for continuity with a multimeter to make sure the connector is seated firmly on the board. If you do need to replace the connector, yes you would need soldering skills for sure. If you get fan spin with pressure, I would see if you can just get a new connector and harvest the clip from that and install it on the existing connector.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
@tsunau most likely it does not make contact without the clasp. Yes, you will need to replace it with another SMD connector and solder it to the board. No way around it. You would need something like this part Unless you do know somebody that could remove the connector and solder the ribbon cable right to the board. Tricky but doable.....
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Tsunau 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 41
总计 1,005
