跳转到主内容
加入维修社区 - 创建账户
Xbox Elite 无线控制器 Series 2 于 2019 年 11 月 4 日发布,兼容 Xbox One、X 及 S 系列主机,以及运行 Windows 10/11 的个人电脑。型号 1797。
Left stick drift and delayed response time
The left stick is always drifting. Sometimes it's not noticeable in game but in menu it will cycle up consistently. Sometimes a quick flick fixes it. Other issue is you press the stick in and the action is not always crisp, there is a delay
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
connect the controller to a pc or laptop then open this site, https://gamepad-tester.com/. it will show you how bad its moving. if bad it needs the analogue stick replaced.
这个答案有帮助吗?
得分 2
添加一条评论
Hey Tyrone! I was able to fix it by opening up my controller and cleaning the sensors on the left stick. This helped me a ton.
When you get to step 11, make sure you move both the green plastic housing for the left stick's sensors. The one on the right controls the X axis and the one on the bottom controls the Y axis. You most likely need to clean out the bottom sensor with some canned air and it should work.
Saved me a few hundred bucks by not buying another controller! Hope this helps out!
如何修复 Xbox One Elite 系列 2 控制器中的模拟摇杆漂移
这个答案有帮助吗?
得分 1
添加一条评论
i replaced the analog stick but the problem persisted. i think it might have something to do with a capacitor
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tyrone Palmer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 45
All Time: 4,493
