Why my battery is too weak
Hassan morray Koroma the battery is pretty much the only strong point on this phone. You should explain to us what you mean by the battery is weak. If you need to extend your battery life use the suggestions from here The battery life is only as good as you use it. The more you use it the shorter it gets.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 498
3条评论
My battery is so weak
由 Dore Mone 完成的
Mere mobile ki battery ki life dheere dheere Kam Ho rahi hai
由 Md Azad 完成的
not charge up properly/long enough
由 antonio 完成的
