How to replace the screen protector on the inside screen
how do you replace the screen protector on the inside screen?
You cannot remove the screen protectors on ANY Samsung foldable phone, removing them destroys the screen. It's not meant to be removed(even if it looks like it is). Don't remove it if you want to save hundreds of dollars to get the screen replaced.
Hope I helped :D
这个答案有帮助吗?
This is only true for the Fold 2 and below I think.
This is not true for the Galaxy Fold 2, 3, or 4. Only the Galaxy Fold 1st gen the "screen protector" on the inner display was integral to the display. Subsequent generations the protector has been a separate plastic film. The film generally starts to detach or bubble from the inner seam after 5-7-ish months of use for most owners. The first time this happens, as long as it is in the warranty period, Samsung will replace the protector for free (but you do either have to take it to a Samsung experience store, of which there are very few in the United States, or FedEx it to Samsung and use a backup phone for a week). Licenced repair partners will also replace the inner display screen protector but this will vary by partner and location (i.e. uBreakiFix will do the repair only if the store has protectors in stock and the jig needed to perform the replacement).
I went to an authorized Samsung repair center you break I fix/assurian and they remove the inner screen screen protector to replace it and then did a faulty job. When I went back to get them to correct it, they said that no more of the screen protectors for the fold three were available. All back ordered. Anyone know where I can get one. I'm happy to buy the part and take it to the repair center to have them install it.
Just peel it off. On Fold 3 its not part of a display and after a year it will start removing itself anyway. Highly recommend having replacement at hand.
这个答案有帮助吗?
Where can I buy a replacement screen protector. All of the ubreakifixes in my city are out of it and they say it's backordered
Doug from UK . As stated my protective screen bubbled on the fold ruining the display experience, probably about 12 months after purchase. Unfortunately I didn't google the problem and simply removed it not realising I could get a free repair. I bougt a replacement protector but it proved impossible to fit so continued without. Screen now cracking along fold and phone out of guarantee period. Great phone initially but nor worth the expense. Thinking of the Google fold now or reverting to normal screen.
这个答案有帮助吗?
Can you fix my fold 3 ....the screen have got link from the inside....someone said need to xgange the while screen
这个答案有帮助吗?
The screen protector tears down on its own. It happened to me after a few months on a new phone, then again after servicing it, and now, after another service, it took just two weeks for this foil to come off.
It'll be great to be able to buy screen protectors on our own and receive service instructions on how to glue them in.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 80
总计 7,117
