跳转到主内容
加入维修社区 - 创建账户
Craftsman(工匠)品牌圆锯的维修指南。
How do I test the switch
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
What is the model number of the saw?
由完成的
I also have a Craftsman circular saw, model #6365. It does not work so I imagine that the switch is the problem. Any ideas on how to troubleshoot?
由完成的
添加一条评论
2个答案
最有帮助的答案
To test the switch, you need to access it. You'll have to open up the casing to access the trigger switch in the handle. Once you can access it, check for continuity across the switch. Then, with your proves still in place, pull the trigger and activate the switch. If it reads OL then the switch is bad.
这个答案有帮助吗?
得分 1
添加一条评论
Hi @bigbob61660,
Go to searspartsdirect.com and search for Craftsman 6365 to hopefully find the parts diagrams and user manual.
If there, this will help to dis-assemble and test the switch etc.
Disconnect the power to the saw and use an Ohmmeter to test for continuity from the saw's power cord plug through the switch - both wires.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
William Speraw 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 1,022
