跳转到主内容
加入维修社区 - 创建账户
2019 年 3 月发布,型号为 SM-A305FZRFINS
How to fix the battery
When my battery gets to 25% it comes to 0% so quickly
回答此问题 我也有这个问题
这是一个好问题吗?
得分 16
6条评论
Battery problem fast finished pleas reason
完成的
Phone camera dirty problem
完成的
Portuguese: Minha bateria está estufada e quando eu tiro o cll do carregador em poucos segundos ele desliga e liga descarregado
Ops: mesmo em 100%
Inglesh: My battery is full and when I take the cll out of the charger in a few seconds it turns off and on when discharged
Oops: even at 100%
完成的
完成的
How fixed to device bettery
=== Update (09/06/23) ===
How to repair Mobile bettery
完成的
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
Use the phone until battery gets 15 : 20%, then put your phone on flight mode and reduce brightness then use this code
*#0228#
It will restart your battery.
Charge your phone until 100% for the first time
这个答案有帮助吗?
得分 4
添加一条评论
Try this:
  1. Use the phone until the battery gets to 0%
  2. Turn the phone on and wait for it to shut off
  3. Keep turning the phone on until the phone battery is pretty much drained
  4. Plug the phone into a charger
  5. With the phone off, keep the phone on the charger until the phone had been on the charger for a few hours after reachy 100%>
  6. Try the phone and see if the problem still arises.
这个答案有帮助吗?
得分 3
1条评论:
Change camera
完成的
添加一条评论
This is common when your battery is getting old. It happens after 3 years of use. Please plan to change it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
I am Me 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 3,318
