跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
Repurposing iMac to become a display
Hi,
I'm currently researching on ways to repurpose my iMac to being an external display. Since I would have the speakers, I was wondering if anyone knew an implementation on how to have the speakers connect to this display panel board https://www.aliexpress.com/item/33014928...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Giovanni Morabito the description does not show the board well. Since it has an audio out jack for headphones I would use that with a small pre amp. Easy build and not to costly at all.
这个答案有帮助吗?
得分 0
5条评论:
@oldturkey03 any preamp suggestions? and also how could I get the preamp to have power
完成的
I saw this video https://youtu.be/7HEkJgU0SLA and it seems they used a preamp of https://www.aliexpress.com/item/32790068...
完成的
@Giovanni Morabito that's what I'd be looking at. You can get the power from the same AC adapter that your are going to use for the driver board. You know it's going to be a fun build.
完成的
@oldturkey03 any videos to show how to wire from an ac adapter? never really worked with wiring before LOL
完成的
@Giovanni Morabito not really but go ahead and purchase the driver board etc. Once you get the parts let us know (and see) and we can draw you up some simple diagram.
完成的
添加一条评论
添加你的答案
Giovanni Morabito 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 322
