跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
any solution for the 23 error?
exist any solution for this problem? i have an iphone 3g with this problem (error 23). have i change the battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I would definitely start with a new battery. MAke sure you get a 3G compatible one. It is POSSIBLE that this causes the error. You might want to try a search on Error 23 on here. I also recommend you look at this question. azusbear on this question says he found a solution as well. My suggestion would be to start with a new battery and go from there. Hope this will get you started.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jhon alexander Latorre garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 380
