跳转到主内容
加入维修社区 - 创建账户
A DVD player by Sony, released in 2002.
CD opening isn't opening
  • CD opening isn't opening
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Need a bit more here!
∙ Do you hear any sounds?
∙ Is the player powering up?
∙ Do you get an error code on the display?
完成的
Do you have a multimeter?
完成的
添加一条评论
1个答案
Ali HD1 you really did not give us a lot of information. It sounds like you are saying that your tray is not opening. You should also tell us more about the history of this and what you have tried thus far to fix this. I suggest that you run the Test mode to see if you can make a better diagnosis on what has failed. Sony DVP NS715 Test Mode
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ali HD1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 220
