跳转到主内容
加入维修社区 - 创建账户
Is this a reasonable fix or should I buy new?
[image|2628444]I've had an LG smart tv for about 8 months. One day I began having strange color Distortions that seem to bleed from certain objects as they pass. It's not an all the time occurrence.  If you look near the pause icon and near Rikers throat you can see it. Most of the time it's colors spilling off moving logos and yellows and greens playing off each other.
I typically noticed during gaming and non animated shows. I've swapped HDMI cables, tried all available ports, done a factory reset, and used different video game consoles. Is there a fix or this tv shot? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
This is likely an issue with the LCD panel. It may cost more to replace the LCD than the TV is worth.
这个答案有帮助吗?
得分 2
1条评论:
%#*@. That's what I was afraid of. Thanks for the quick response. Looks like I'm off to Best Buy thus weekend.
完成的
添加一条评论
Matt Khourie color bleed like what your images shows, can be caused by a bad T-Con board or a bad main board as well. I would not yet give up on this. You did not tell us what exact model your TV is so you are a bit on your own researching the main board/T-Con board. Try to get a used one and see if that makes a difference. If you got to buy new get it from a place that has an easy return policy. I am not convinced that this is a panel issue. Possibly but you want to check other things as well.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Matt Khourie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 604
