跳转到主内容
加入维修社区 - 创建账户
Alienware 17 R2 的设备维修和故障排除指南。该设备是 Dell 在 2015 年推出的美国电脑,现已停产。该产品专为游戏设计。
Can't boot or run diagnostics
Any OS boot, (Linux/win10/dell diagnostics) from USB DVD hangs. Diagnostics starts but goes blank ( power lights still on) in middle of run. Removed all drives, same result. Windows install media won't complete boot. Hangs. Acronis boot DVD starts, then hangs on Grey screen. Can access BIOS. RESET BIOS no change in status.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Four questions:
  1. Have you (re)flashed the BIOS with the latest version?
  2. Taken out and reseated RAM modules and swopped them around? Also run memory test, if possible? It may pin point the error.
  3. Connected the laptop to an external monitor or TV to see if the screen is defective?
  4. Disconnected the battery and tried running laptop from just powersupply/charger?
Service Manual for your information:
https://dl.dell.com/topicspdf/alienware-...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Frank Paulsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 417
