跳转到主内容
机器可读指令,可以指导计算机处理器从互联网上下载和渲染“猫”的图像。
How to Transfer WhatsApp to New Phone?
I needed to discard my old phone and got into trouble transferring my WhatsApp data to my new phone. I'll be using the same phone number. How to ensure that all my WhatsApp data will be transferred to my new phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Hi @keiramos ,
Here's a link that may help.
这个答案有帮助吗?
得分 3
添加一条评论
此回答最初是针对另一个问题
Hello there, having a problem transferring your WhatsApp messages from one Android to another? If you don't have any idea on how to do this, then this might help you; https://echoshare.co/transfer-whatsapp-m... - it will give you ideas that I'm pretty sure will help you out.
这个答案有帮助吗?
得分 2
添加一条评论
此回答最初是针对另一个问题
Hi, you can use Local Backup to help you transfer WhatsApp Messages from One Android to Another Android as below:
1. Run WhatsApp on your old Android phone.
2. Go to WhatsApp Settings > Chats > Chat backup > Back Up. Then your WhatsApp chats will be saved to File Manager > WhatsApp > Databases.
3. Transfer WhatsApp chats to new phone. If your old phone has an external SD card: you can take out the SD card from your old Android phone, insert it into your new Android phone and copy the WhatsApp backup file from SD card to new Android device.
If the WhatsApp backup file is in old Android phone's internal memory card, you can find it and transfer to new Android phone via Bluetooth, Wi-Fi or computer. Note that it is possible to lose some files during transfer.
If you want to try other ways like Google Drive or a pro Whatsapp transfer tool, you can check this article. Hope this will be your help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Klarence Ramos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 847
