跳转到主内容
加入维修社区 - 创建账户
CFS-204 是一款 90 年代风格的模拟 AM/FM 收音机和盒式磁带播放器。它可以使用六节 C 型电池供电,也可以通过标准的墙壁插座使用交流电供电。
Warning about opening plastic case
I have a similar Sony CFS-B11 with, I suspect, a broken belt in the tape player mechanism. The case carries dire warnings about electrocution upon opening the case. What do I need to do, beside unplugging the radio cassette corder from the electrical outlet, to open the case safely?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks! So helpful!
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @sandhillgirl,
You may get a tingle from some capacitors discharging if you accidentally touch some sections of the power board with your fingers but that's about all. To prevent this from happening, after you've disconnected the power from the player, turn it on for a few minutes, to discharge any remaining charge in the capacitors. It won't turn on of course, but they will still discharge in trying to turn it on with no power connected ;-)
Here's a link to the service manual that will help. Be patient as it takes a little while to find the file after you have passed the security check.
It shows how to disassemble the player and the belt can be seen on p.6 in the tape adjustment section.
The belt part number is Sony 3-362-989-01. Search online using the part number only to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lisa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 616
