跳转到主内容
加入维修社区 - 创建账户
配备与大型机型相同原装 Saeco 技术的紧凑型咖啡机。
How to remove stucked brewing unit
How to remove brewing unit if it stuck
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Why does it stuck? Try to move the unit using the test mode, until the arrows on the yellow main axis match. This is the position to pull out the unit. If this doesnt work you have to use a somewhat rustic method: about two cm left from the yellow axis is a hole. Insert a Torx T10 screwdriver and loosen the screw on the opposite side. Hopefully you now can pull (pulling rather strong) out the unit. The inlet nozzle on the opposite side should now be stuck in the unit. Remove it. Good luck, hope it works - but there ist no guarantee.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Joseph Goodman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 961
