跳转到主内容
A digital SLR camera by Nikon sold between 2005 and 2006.
Nikon D50 built-in flash does not work
The flash does not work. The flash will pop up when shutter button is pressed, however the flash does not fire.
Fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Stan Keenum, of course your ISO setting is around 400. the flash will not work if your ISO setting is high. I would think that if nothing has happened to your camera and this just came up, that the first thing I check for would be the main condenser and the wiring to the DC-DC board. Also check the popup switch. You can download the service manual for your camera from here
这个答案有帮助吗?
得分 3
5条评论:
I have a bad flash on my D50, can you please share the service manual again for it? Thanks.
完成的
You can Try it now
完成的
Thank You!
完成的
完成的
Bill, try it now
完成的
添加一条评论
Hi, i cant access the manual, could u please share again
Many Thanks
Matt
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Stan Keenum 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 3,715
