跳转到主内容
The Sony Cybershot DSC-W55 was released in early in the year 2007. It is upgraded with a 7.2 megapixel camera compared to the previous model's 5.1 camera and has 56mb of internal memory.
Flash has stopped working, is it fixable?
Flash not working, is it fixable?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
οταν αναβω η καμερα πηγαινοερχετε και δεν σταματα τι μπορω να κανω και που
完成的
error 91:01
完成的
添加一条评论
1个答案
最有帮助的答案
chris, you did not mention if you get an error code. Anyhow, you can of first try to reset your camera by first turning of your camera. Remove the battery or external power supply. Press and hold the power button for 30 seconds. Install the battery or external power supply. If that does not work, and you are sure your flash is on, you may have to replace the flash assembly. The instructions for that are here. You can also download the service manual for your camera from here. The part number is 1-479-663-31 and it is available at places like this. On the assembly, you will find a large capacitor, check that one for bulging and leakage. It is possible that all you need to do is to replace is that. Might cost you a few $$ but cheaper than the assembly. Hope this helps and good luck. Let us know how it turns out.
这个答案有帮助吗?
得分 2
1条评论:
usefull
thanks
完成的
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 4,014
