跳转到主内容
加入维修社区 - 创建账户
1.5 GHz Core Solo、1.66 或 1.83 GHz Core Duo,或 1.83 或 2 GHz Core 2 Duo 处理器。 本页面涵盖了从 2006 年初到 2007 年中的首批基于 Intel 处理器的 Mac mini 机型。
Mac mini 2007 dead
Hi everyone,
I recently bought a dead Mac Mini from 2007. But when I try to power it on, there is nothing, no light, no chime, not any sound from it. I took apart the logic board and everything seems fine. The charger is working because on the second one i have, it works perfectly.
Do you have any suggestions to measure with multimeter ? Because I’m used to laptops not Mac Mini’s. Thanks :)
Update (03/24/2022)
On the global photo, it’s at the top right
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
Can you take a second picture so we can at least read the logic board labels and the cap if its still intact in the location it was located.
由完成的
@danj hello, i removed the capacitor the motherboard is a 820-1900-A from 2006.
由完成的
It has the same size as the others next to it @danj
由完成的
@anthony10006 - Just because it looks the same doesn't mean its the same values.
由完成的
Yes i know. Unfortunately, i can’t find any schematic for this board :( @danj
由完成的
添加一条评论
2个答案
已选择的解决方案
Le problème venait d’un condensateur en court-circuit. Maintenant le mac remarche mais il me reste à remplacer le défaillant.
The problem was a shorted capacitor. Now the mac works again but I still have to replace the faulty one.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Have you tried just replacing the PRAM battery?
You may need to take the logic board fully out so you can inspect the other side. Look for a component that looks discolored or burnt. Often the electrolytic & tantalum caps breakdown. Mac mini A1176 型号逻辑板更换
这个答案有帮助吗?
得分 1
5条评论:
@danj Hi, thanks for your fast answer. Is it possible that the mac could not turns on due to an issue with the pram battery ? Also, as i saw, i didn’t manage to find some dead caps on the logic board, the only thing that i noticed it that a ceramic cap looks weird near the cpu, it is a bit brown not as usual. So i used my multimeter to test for continuity and i have a value of more than 1100 on the line and this seems weird. Thanks
由完成的
@anthony10006 - The older systems need the battery to work properly. I would start there.
由完成的
@danj hello, i found a dead capacitor and now the Mac works. But i can’t find a schematic for this model. Have you got one please ? It’s 820-1900-A for the board model. Thanks
由完成的
@anthony10006 - Sadly I haven't found any for the Mini's. Best to ID the cap's specs how about posting both images of the cap and the location on the logic board. 在已经存在的问题里加入图片
由完成的
@danj ok, i will send the image in the answers
由完成的
添加一条评论
添加你的答案
Correia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 673
