跳转到主内容
加入维修社区 - 创建账户
Lenovo 300e 是一款搭载 Intel 处理器的二合一笔记本电脑,也是一款多功能的学习工具。该设备配备一个充电器和 3 个内置 USB 端口。
How to bypass managed admin lock?
How do I bypass school administrators lock?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
with the school administrators password…
can you elaborate as to whats going on?
这个答案有帮助吗?
得分 1
添加一条评论
There is no way that you can truly bypass them unless your school district has forgotten to lock Crosh (Chromebook command line) and even then it requires you to open the machine. Launch developer mode and basically re-install an OS.
If you need more information read up on https://mrchromebox.tech/ but again this will NOT work unless you are a District Administrator. You just won't be able to launch Crosh.
这个答案有帮助吗?
得分 1
1条评论:
so there is no way to get rid of restrictions?!?!
由完成的
添加一条评论
if you can't get into developer mode thru settings press esc+refresh and tap the power button then press ctrl+d next press enter then ctrl+d. this does not work on all chromebooks and if you have a lenovo 300e the hard drive is not removable so you can't run linux from a usb stick
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyle Bowman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 1,568
