跳转到主内容
GMC 汽车、卡车、SUV的修理和支持指南
292 个问题 查看全部
My running lites blinkers and guide lights real dim on right side
GMC 2000 jimmy
Running lights blinker and indicator light real dim . Ok some one stole my head lights and cut the plugs when I went to replace I had to fined A new ground on the right side well I used the ground that went to the day running light that also went to horn . Well now that ground has voltage . Where do I start to solve this ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
hernandezsean240 “I had to fined A new ground on the right side well I used the ground that went to the day running light that also went to horn . Well now that ground has voltage”, This sounds more like you are connecting the wrong wire from the light. Ground for your light would be pretty much anywhere on the chassis or even the frame. This schematic should work for your Jimmy
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
hernandezsean240 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 21
