跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Blotchy area on new screen
My son dropped his iPod and broke the glass. I purchased a new screen with digitalizer attached, installed and closed it up. I then discovered the wifi antenna was broken. When opening again the layers of paper and such came separated from the glass. The new wifi antenna worked, and the screen still works. But now I have a greenish gray blotch right under the word iPod. The blotch seems to grow. I'm wondering if it is possible to fix this, or if I need purchase yet another screen and try again...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
docbill, probably not. It sounds like it has, or is, separating. Try to contact the vendor and see if you can get a replacement for it.
这个答案有帮助吗?
得分 1
添加一条评论
PROBABLY THE PROBLEM IS WITH THE LCD QUALITY YOU HAVE BOUGHT BUT CHECK FIRST THAT THE SURFACE OF THE LCD FRAME IS CLEAN WELL AND YOU ARE USING THE RIGHT STICKER
(not so thick) during assembly coz, it will cause blotch when lcd surface is press. hope this will help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
docbill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 986
