跳转到主内容
Repair documentation and service information for Hisense televisions.
Tv showing full screen verticle coloured lines
Hey I was just watching TV and this happened
Then when I like change to a different screen it changes too
Updated pictures for old Turkey
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
[video|3853] I've attached a video
完成的
添加一条评论
1个答案
@itsclarkey looks like either the main board went on the fritz or the panel. If your audio is gone too it’s most likely the main board. Time to open it up and check the boards. Post some good pictures of those with your QUESTION. that way we can see what you see. Of course, do not touch anything on those boards with your fingers. We need pictures since there are no schematics to speak off for the Hisense TV’s 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
8条评论:
Aww really so it ain't just the t con board, I had it open earlier to look and see if ribbons weren't connected properly and well cleaned but didn't get anywhere, I'll have to take it apart again, is there anything specifically you want pics off
完成的
@itsclarkey picture of the boards would be good. When the T-con board goes on the fritz you usually end up with a black screen. Do you still have sound?
完成的
Hey @oldturkey03 I tested and the sound still works perfectly
完成的
pop it open and lets check the boards.
完成的
Okay will do shortly
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Kyle clarke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 86
