跳转到主内容
加入维修社区 - 创建账户
DualShock 2 模拟控制器随 PlayStation 2 一起推出,除了螺丝位置等细微的外观变化外,与前代几乎没有区别。
Ps2 controller buttons not working (Circle and Triangle)
Square and Triangle simply don’t work as if there are no connections between the buttons and the whole system.
Any good guide to fix this?
Thanks,
Andrew
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I believe it's the rubber push button thing is that are under the buttons.
DualShock 2 拆解
这个答案有帮助吗?
得分 2
添加一条评论
The ribbon cable that reads all of the button inputs is pretty fragile and degrades over time. You might need to replace it with a new one; they usually only go for a dollar or two each on ebay.
You will first need to take your controller apart and check if the connector has A) 18 or 19 pins, and B) a removable or attached cable. You can find the Dualshock disassembly guide here:
DualShock 2 拆解
Mine had 19 and was attached:
If it’s removable, it’s a super easy drop in replacement and you won’t need to replace the connector. If not, you’ll need some soldering skills to remove the connector and replace it with a new one. The connectors usually ship with the cables but make sure before you buy. Once you do this the cable will now be removable, so if it ever degrades again it will be easy to replace.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 29
过去 30 天: 178
总计 7,803
