跳转到主内容
加入维修社区 - 创建账户
A1418 | EMC 2889 | 2015 年末款 | 1.6 GHz 双核 Intel Core i5 或 2.8 GHz 四核 Intel Core i5。发布日期:2015 年 10 月 13 日。
LCD Inverter Power Backlight Cable
Hi, there. Wondering what’s wrong with this top LCD light (please refer to attachment)? As it won’t on when iMac is turn on, the other 3 LCD lights are OK. Is it LCD Inverter Power Backlight Cable is faulty? Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
完成的
Thanks, Dan. I thought the image was uploaded together with the post.
完成的
添加一条评论
1个答案
Reconnect the display making sure you properly seat the connections. Use some painters tape to hold the display. If you get an image tale a picture and post it. If you don’t plug in an external display does it show your desktop? If you can’t do that take a flashlight pressed on the display in a dimly lit room you should see a faint image of your desktop and/or do you see a slight glow from the display?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kenny Sim 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 349
