跳转到主内容
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
20 个问题 查看全部
ZG5 wont charge or turn on
hi guys,
my mrs has a zg5 notebook and on sunday she noticed that the notebook wouldnt charge unless the charger was fiddled with and in a wierd position, the following day it wont turn on and it wont charge. not do any lights come on when the charger is plugged in, the orange light flashes 3 times when i hit the power button but thats it. Im not sure if its the charger cable, the port where the charger slots into on the netbook or something else. im considering a tear down and the guide looks straight forward, im just looking for some possible reasons to help me fix this from you guys please :)
Thanks
Steve
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There is the possibility that the charger has a broken connection on the DC plug. Gt a multimeter and plug in the charger. Attach the multimeter to the DC plug and see if you have any output. Move the plug around and see if it either gets power or loses power. It is also possible that the DC adapter on your mother board has either come loose on the board or has broken solder connection. The only way to determine that is by opening it up and using a multimeter to see if you are getting power with the AC Adapter plugged in. Hope this will get you started and let us know what you find out. Good Luck.
这个答案有帮助吗?
得分 2
6条评论:
thanks, i will do this tonight, just need to work out how to use the multimeter my father got me at xmas ;)
完成的
put it on DC voltage + tip - barrel Most multimeter have Black probe for - and Red probe for + Set it at a range of about 50 V, not sure what meter you have, but should work out. ;-) http://www.laptopparts101.com/ac-dc-powe... Good Luck
完成的
thanks oldturkey! i tried this and i couldnt get the meter to read anything but 0.00, however i can hear an electrical click when i connect the colverleaf cable to the chager block so i suspect it is the charging brick that has died. i think its worth a chance getting a new one as they are only £5 off ebay? thoughts? thanks again
完成的
Yes, absolutely. Cheaper than a new computer :-) Good Luck.
完成的
thought id provide an update. I purchased a new power brick from ebay for £5 and its all good as new, battery charged fine and were all back up and running, thanks for the help guys :)
完成的
显示更多的1条评论
添加一条评论
ok does anyone happen to know the power-connector on the motherboard itself's specs? the center-post for the connection in the laptop apparently broke off .. was considering just saying the !^@% with it and soldering the power connector wires together making in effect a permanent powercord, but if its plausible to buy and replace that connector... *lol* 3razar3@gmail.com
这个答案有帮助吗?
得分 0
1条评论:
You can get the parts from here http://powerjack.us/index.php?main_page=... amongst multiple other places like digikey.com or mouser. com and here is a decent side that shows about the how to http://www.powerjackrepair.org/aceraspir... hope this helps, good luck.
完成的
添加一条评论
添加你的答案
Steven 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 4,115
