跳转到主内容
Repair information for pogo sticks.
3 个问题 查看全部
What can replace the bottom that hits the pavement when u jump?
A very old pogo stick needs the rubber on the bottom replaced and also the foot pads. What can I use to fix this? Also, should it be oiled? Thank You!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
The pogo stick was manufactured by the Hungerford company that was in Rockaway NJ. It has a US patent # 2.518.986 and it also shows "5/8 model" I am looking for a replacement tip and foot pads.
完成的
添加一条评论
2个答案
已选择的解决方案
leslie laemmli check on here these might not be exactly for your pogo stick, but you might modify those to fit your Pogo stick. Also check on here. If you can, let us know what brand you have. As for lubrication, some have some oiling points on the tube in which the spring sits. they may be covered by some plastic tabs. Another great site about the Pogo Sticks is right here Hope this helps, good luck and let us know.
这个答案有帮助吗?
得分 2
1条评论:
I am looking the rubber foot rests and the rubber base for Rapco pogo stick. Can you help?
完成的
添加一条评论
I would use duct tape. Yeah it probably should be oiled, but only on the moving parts where friction is created.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
leslie laemmli 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 29
总计 5,948
