跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
After replacing battery doesn't even start.
Sorry for my language, i'm not native speaker.
Hello everyone, i have iPhone 3gs. After replacing battery to not original (Palmexx now i don't have any battery besides this), phone doesn't turn on, itunes see it in recovery mode, but screen even doesn't blink. I can restore it, but in the end i have error 29. I've checked motherboard and didn't noticed any damage or any problem with tails (i hope i chose right word). When connected to the PC it gets warm. Again sorry for my language, and i wanted to ask if this problem becouse of the bad battery or becouse some other part of the phone was damaged?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I believe that error 29 is problem associated with a non-original battery and also a not original USB cable. If the cable you are using has worked before, you can rule it out. Change your battery to a different one (best is to get it from ifixit) and your phone should work again. As an alternative, You could try iRecovery and see if that will help you. Good Luck.
iPhone 3GS Battery
Here for iRecovery
Replacement 1219 mAh battery for iPhone 3GS. Compatible with all iPhone 3GS models. Does not require soldering.图片
产品
iPhone 3GS Battery
$14.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Vitaly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,500
