跳转到主内容
The Xterra was introduced in North America in the 2000 model year (1999 calendar year) and marketed using the tagline Everything you need, nothing you don't.
13 个问题 查看全部
Can a bad valve cover gasket cause smoke from the exhaust muffler
Got a question..can a bad valve cover gasket cause my 2004 Nissan exterra to smoke from the exhaust muffler..im replacing the valve cover gasket right now.. please answer my question please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Roro Valdez, no it cannot. There may be some oil dripping onto the exhaust (header) and most of the smoke would be in the engine compartment. Smoke coming from the back of the exhaust pipe is caused by the combustion itself. It could be burning oil or coolant. You need to take a look at your spark plugs and see what those look like at the electrodes. If they are blackened, oily and sooted your engine is most likely burning oil. If they are kind of rusted looking it is most likely coolant. The repair of this will be depended on what you find out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Roro Valdez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 35
过去 30 天: 161
总计 1,877
