跳转到主内容
加入维修社区 - 创建账户
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
What does Jtag do?
I’m wondering what “Jtag” on the motherboard does,
What it connects to,
I’ve lost the cable in side the machine
@danj @oldturkey03
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
So. The thing with the JTAG connector is, it likely didn’t have a cable. JTAG connectors are for performing board level functions, checks, debugging, etc…. So end users will generally never have to make use of them. In fact most modern Mac boards (the production models anyways) have pads for the connector, but nothing soldered there.
So really. You didn’t lose it. You never had it.
这个答案有帮助吗?
得分 5
7条评论:
Ok thanks,
i was panicing i thought i lost it (i didn't though)
完成的
What does BLC_ACDC on the mother board do?
完成的
Anyone????????
完成的
What does this connector do? Empty connector on the logic board
Also should be empty. From what I can tell. The schematic indicates it has communication lines that would indicate some relationship to display functionality. But it may have been something they decided to scrap later in the design process. Either way. The fact that you don’t have a cable for this is normal.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Ben Capehart 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 23
总计 765
