跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
695 个问题 查看全部
What does this connector do? Empty connector on the logic board
Hi everyone! I've tried to google this but can't find something about. What does this empty connector on my logic board does?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
已选择的解决方案
@arkcyd according to my documentation this is J602 which is the MLB to BLC connector. Looking at the schematic it is not a test point for the logic board but at best for the backlight. See if this will help you further with your research
这个答案有帮助吗?
得分 4
评论:
@oldturkey03 Thank you! :D
完成的
添加一条评论
Yes, very interested in J602.
Can anyone define the function of this Connector J602?
There are common connections between J602 and J9002 (LCD data connector).
for example, signals SMB_BLC_TCON_SDA and SMB_BLC_TCON_SCL connect to both connectors.
I think these two signal provide data/clk to the chip on the LCD board relating to the LCD temperature sensor.
The LCD temp sensor connector is on the LCD panel board itself,
I have two IMACs and plan to use REMOTE MANAGEMENT to see the Display of the 2011 iMac on my 2019 iMac.
I plan to remove LCD PANEL, but FANS go crazy with LCD temperature sensor issue.
AHT results in 4SNS/1/C0000008 TL0p — 124 which is LCD temp sensor issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
arkcyd 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 12
过去的30天: 58
总计 3,550
