I cant open the lip and I spilled coke on my pc, how do I open it
So I spilled Coke on my pc and now it’s not turning on, it recently came back on but went off again, can someone please help me?
Muffin Heeler for now stop continuing to use or charge your computer. This potentially can make a bad situation worse.This may further damage your laptop. Unplug it and remove the battery.
The next thing you need to do is to clean it. Disassemble your laptop using phone using this service manual. The first thing to clean is your motherboard. Clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a cellphone, all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When the board is properly cleaned, focus on all connectors etc. do not forget your touch pad and keyboard connectors etc. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done (now is a good time to take really good pictures of your board connectors etc. in case you’ll need them later). Reassemble your laptop and reevaluate. Until it is cleaned, everything will only be a guess.
If you find anything odd, or anything you are concerned about, post some good pictures with your QUESTION.在已经存在的问题里加入图片
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 199
