跳转到主内容
Samsung Galaxy Tab A 10.5 includes two model numbers, the SM-T590 (Wi-Fi), and the SM-T595 (LTE).
6 个问题 查看全部
Samsung tab A7 2020 will not power on, does not show charging
I changed out my charging port, put it back together and nothing. It will make a sound when I plug it in otherwise absolutely nada. I double checked all connections. I have tired holding the power button for as long as 1 to 2 minutes, same with power and volume down. I unplugged the battery for 10 minutes and removed the sd card. I have trickle charged it with my computer (does not show up, so its not on or has 0 battery) and travel charger. Nothing. I think the batter is at 0. I am on the verge of tossing it but I feel like it is something easy (plus it's only a year old) my next step is to try to jump start it with a 9 volt battery. Otherwise I am at a total loss. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@pittypat. your battery will not charge if it is below it's threshold of ~2.9V-3.0V. Of all the thing you have already tried, replace the battery. that way you have a Known-Well starting point. After that you will have to dig down deep
这个答案有帮助吗?
得分 2
添加一条评论
Sounds like you likely have a defective charge port.
这个答案有帮助吗?
得分 0
1条评论:
I just put in a new port.
完成的
添加一条评论
添加你的答案
pat allred 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 55
总计 1,702
