跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Only Left Touch Screen working
I replaced LCD and broken glass, in the process I might damaged connector 3 and maybe other parts of the board.
When I close the IPhone, the screen display ok, the battery is charging, but the touch screen is working only on the left half side - I cannot scroll right to the end to unlock the phone.
What can be wrong? Should I need to replace the whole board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Always double check your connection and make sure they are seated right and that you did not end up bending a pin or similar. Of course also make sure you have the right part and did not get the 3G part. If any and all of this works out okay, I would think that it is your digitizer. Usually, if it is something on the logic board, you have an overall non-functioning digitizer. If part of the digitizer is not responding, it is the digitizer that needs to be replaced. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Amit 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 929
