跳转到主内容
加入维修社区 - 创建账户
型号:A1419/2012 年末/2.9 & 3.2 GHz Core i5 或 3.4 GHz Core i7 处理器,ID iMac13,2
How do I remove hard drive
iMac 2012 black screen
A1419 iMac, powers on but LED backlighting doesn’t light up.
Apple genius says my drive is dead. I want to remove it and get the data stored on it. They siad there are services that can do this. My last backup with Time Machine is pretty old.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi
It’s fairly easy to do you just need to pop the glass off ,remove the display and remove the brackets that hold the hard drive in place
Heres video that shows sep by step
https://youtu.be/OXmHGrr4Vkk
I know the video is about a ssd upgrade but it’s the exact same process and just a little warning below the hard drive there is a power supply DO NOT TOUCH IT (sorry if that sounds aggressive)but really don’t as the is a chance you could get a shock of if it which I’m pretty sure can kill you ,however I have done the sort of repairs before and had no issues so as long as you are careful you will be absolutely fine
If you have any Questions please ask
这个答案有帮助吗?
得分 2
2条评论:
Here's the iFixit written & video guide iMac 因特尔 27" EMC 2546 硬盘更换
由完成的
Hi
I would recommend using the video that Dan had provided as it is a ifixit guide a will be waaaaaaaay more in depth than the video I provided
由完成的
添加一条评论
OK, so here are my recommendations:
  1. Start by confirming your A1419 iMac is a Late 2012 27” with iMac ID 13.2. The following should cover all iMacs from 2012 through 2019
  2. Watch OWC’s removal/installation video here (OWC has been supporting Apple computers for DECADES)
  3. I highly recommend purchasing OWC’s iMac tool kit ($25). You will need to remove the screen, and it is glued in place. Take your time and it will come off.
I do not and have never worked for OWC, but I did work as an Apple tech for 17 years and after trying many companies’ parts, will only deal with OWC to keep my iMacs going.
Take your time and it will all come together.
这个答案有帮助吗?
得分 1
2条评论:
@mrmattdat - We do try to aim people to the iFixit tools & guides iMac 因特尔 27" EMC 2546 硬盘更换
Remember they are the ones offering this Blog space!
由完成的
Gotcha! Love the tools (top shelf!!!!), just never had a chance to use the guides (yet!)
由完成的
添加一条评论
添加你的答案
Bob Enders 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 19
过去 30 天: 77
总计 1,429
