跳转到主内容
Device repair and information for the Dell Alienware 15 R3, a gaming laptop in the Alienware series.
14 个问题 查看全部
Spacebar cracked, how do I replace?
Was trying to remove the spacebar to clean and it cracked. Where do I get a new one and how do I replace it properly?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Is this an internal laptop keyboard or a separate desktop keyboard?
完成的
William Waite your computer is a Dell Alienware 15 R3?
完成的
Duh, I see it now. Have you reached out to Dell to see how much a replacement keyboard is? That helps in computing a repair. It should also get you to install instructions to help you removing the keyboard to look at whether and how you can repair it.
完成的
Internal keyboard. Yes, Alienware m15 r3 I believe. I have not contacted Dell. Taking it to a repair shop tomorrow for analysis and estimate.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi ,
You may be able to fix it yourself.
Here’s a link that will help with this. Select your key and key type
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
William Waite 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 223
